If you're traveling and accidentally filled up with ethanol gasoline, but still have a few hundred kilometers to go, can you continue driving and use the highway?
The 10-year-old Galant has driven over a hundred kilometers on the highway, and the gearbox is making a whistling sound. What's going on? It seems fine when the car is cold.
What is the fuel tank capacity of the TRD Adventure edition? The specs say it's 87 liters, but I can only fill up about 60 liters. What's going on?
If you're considering switching to a Model X, the delivery time can vary depending on your location and the specific configuration you choose. Typically, it might take a few weeks to a few months for delivery. It's best to check directly with Tesla for the most accurate and up-to-date delivery estimates.
4Why is the dashboard still showing "add windshield washer fluid" even though I've filled it up and it's spraying normally? Any suggestions?
5What could be the issue if the fuel gauge is empty, you fill up the tank, and it still doesn't respond?
6The fuel tank capacity of a Jetta is generally around 55 liters. If you're filling up about 57 or 58 liters each time, it could be due to the fuel already in the tank or variations in pump measurements.
7When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
8If you're traveling and accidentally filled up with ethanol gasoline, but still have a few hundred kilometers to go, can you continue driving and use the highway?
9Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
10Didn't they say this car was discontinued? Why are there still a few hundred sales every month, just going steady? Aren't people worried about after-sales issues?
