I've noticed a "pop" sound coming from the front of the car when it's cold. Once I start driving, everything seems normal. The dealership said they'd need to keep the car there to check it. Has anyone experienced a similar issue? What could be wrong? It's happened multiple times already.
Hey guys, my Land Cruiser tends to pull the steering wheel when driving on bumpy roads, and it doesn't feel very stable. I've already done a wheel alignment, and the mechanic said there's nothing wrong. Is the steering wheel pulling a normal phenomenon?
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
4The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
5I was driving a Haima S5 1.6 CAT Creative Edition on the highway for about 6 hours, and suddenly the car couldn't accelerate. After stopping and turning off the engine for a while, it could accelerate again. What could be the problem? This has happened twice already, once on the highway before and once this year. When it couldn't accelerate, the car showed a fault code, but after parking overnight, the fault code disappeared. Has anyone else experienced this?
6I've noticed a "pop" sound coming from the front of the car when it's cold. Once I start driving, everything seems normal. The dealership said they'd need to keep the car there to check it. Has anyone experienced a similar issue? What could be wrong? It's happened multiple times already.
7When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
8Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
9The seat ventilation makes noise but doesn't blow air. The dealership said it might be the sponge slipping, and repairing it would require removing the seat and replacing the sponge, costing over 1000. Has anyone experienced a similar issue? How did you handle it?
10Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦♂️
