I have an 18 model Red Label automatic luxury version. Occasionally, at low speeds, I feel like the gear shifts are particularly delayed and the transmission feels a bit rough. Other times, it's very smooth. Does anyone know what's going on? I changed the transmission fluid at 60,000 kilometers, and it's currently at 80,000 kilometers.
What maintenance does a 2016 Yuexiang V7 manual transmission need at 80,000 kilometers?
Is it possible to get a 2012 Volkswagen Scirocco 2.0 with no more than 80,000 kilometers, no accidents, no fire damage, no water damage, and no tampering for 60,000?
Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
4I have an 18 model Red Label automatic luxury version. Occasionally, at low speeds, I feel like the gear shifts are particularly delayed and the transmission feels a bit rough. Other times, it's very smooth. Does anyone know what's going on? I changed the transmission fluid at 60,000 kilometers, and it's currently at 80,000 kilometers.
5For a 2016 model, does it need a timing belt replacement? At how many kilometers should it be changed? Also, when driving on rough roads, there seems to be a "thud" sound from the suspension. It has just reached 80,000 kilometers now.
6Is it necessary to change the transmission fluid for a 2010 Suzuki SX4 Hatchback 1.6 Automatic that has traveled 160,000 kilometers and hasn't had a transmission fluid change yet? The gear shifting is currently very smooth.
7It's said that performance cars can be troublesome in the long run. Can the Macan S 3.0 be reliable at 60,000 to 80,000 kilometers?
8It is said that performance cars can be troublesome in the long run. Can a Macan S 3.0 be reliable at 60,000 to 80,000 kilometers?
9I want to buy an Alto, should I go for a manual or automatic transmission? Locally, there's a 2013 model that's priced around 13,000 and has run about 80,000-90,000 kilometers. Is it worth buying if it's a manual transmission?
10Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
