نايف أصغر
2024-05-02 13:09
I have a 2018 Haval H2 Red Label with a manual transmission, and the touchscreen display isn't responding. Does anyone know what might be causing this issue?
عبدالله عبد عزيز
عبدالله عبد عزيز2024-06-10 15:32
Just change the frequency.
حسن تاج
حسن تاج2024-05-29 22:55
It's not good on rainy days, but after some sunshine, it's fine again. [I want to be alone]
أحمد توفيق
أحمد توفيق2024-05-27 11:45
The touchpad sometimes malfunctions, but other times it works fine. I could replace it myself, but I don't want to bother with it since it's an old car.
حسن سالم
حسن سالم2024-05-20 19:46
Sometimes it's possible. Buying an Android system online and installing it yourself can be better than the original car system.
Even with power in the battery, my Jinxuan manual sometimes doesn't respond when starting. After turning it on and off a few times, it starts. Does anyone know what might be causing this?
I have an 18 model Red Label automatic luxury version. Occasionally, at low speeds, I feel like the gear shifts are particularly delayed and the transmission feels a bit rough. Other times, it's very smooth. Does anyone know what's going on? I changed the transmission fluid at 60,000 kilometers, and it's currently at 80,000 kilometers.
Why is the engine light on my 2017 Haval H2 Red Label Automatic 1.5T Luxury always on and not turning off?
I just got a 2016 Haval H2 Red Label 1.5T manual 2WD! But I don't know how to identify which version it is. Can anyone help me with this? Where can I find out? I just know it's a high-end model!
I have a 2018 model car registered in March 2019. It has now reached 105,000 kilometers, and I haven't changed the transmission oil. The fuel consumption displayed has always been at 14. [Shocked] I have a heavy foot. Has anyone changed the transmission oil? Where did you get it done, and how did it turn out?
Does anyone know about the Haval H2? Initially, when you pressed once, it would turn off, and pressing a second time would cut off all power in the car. Now, pressing once turns it off, and pressing a second time puts it in a powered self-check mode. Does anyone know what might be the problem? Has any owner experienced the same issue? Thanks!
Haval H2 Red Label 1.5T has currently run 85,000 kilometers. While driving at speeds between 60 to 100 km/h, there's a vibration and noise coming from the front wheels. What could be the cause of this issue?
Hi everyone, I have a 2015 Volkswagen Jetta with a manual transmission. I'm having trouble turning the key in the ignition; it takes several tries and some jiggling to get it to turn. Does anyone know what might be causing this? Any advice would be appreciated. Thanks!
Haval Haval H2
Haval H2AED 54,900Gasoline & Petrol
