حسين لقمان
2024-09-21 13:55
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
أحمد توفيق
أحمد توفيق2024-09-22 11:12
The brake light is out, replace it yourself.
خالد أسماء
خالد أسماء2024-09-22 07:53
Find someone to help you press the brake pedal, then check which brake light bulb is out. You can buy a bulb online for 5 dollars. Get a socket wrench, remove two screws, and you can take the entire tail light out to replace the bulb.
Why does the electronic brake on the MG GS get damaged when you press the brake pedal to release it?
Why does the car show a transmission fault warning during a cold start, but it goes away after waiting and restarting?
The 2014 Zhiya's Blind Spot Detection (BIUS) system showed a fault warning in July this year, but today the fault disappeared and the feature is working again. What could be the reason?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
Haval H2 automatic fashion 2019 model, when pressing the brake, it automatically shifts to neutral and can't shift back. You need to turn off the power and restart to be able to shift. There's no fault code on the screen. Any fellow car owners experiencing the same issue?
Does anyone know about the Haval H2? Initially, when you pressed once, it would turn off, and pressing a second time would cut off all power in the car. Now, pressing once turns it off, and pressing a second time puts it in a powered self-check mode. Does anyone know what might be the problem? Has any owner experienced the same issue? Thanks!
Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
Haval Haval H2
Haval H2AED 54,900Gasoline & Petrol
