avatar-image
سلمان زكريا
Sep 13
I have a 2016 automatic model, and when driving on good roads, I hear a clear "clanging" sound from the right front tire area. Could this indicate a problem with the shock absorber? I just bought this second-hand car, looking for advice.
Comments( 7 )
عبد العزيز هاشم
عبد العزيز هاشم2024-11-22 14:42
I have the same model, mine is a 2014. Try kicking the front wheel, do you hear a crisp banging sound? Mine had this issue because the brake discs and pads were worn out. After replacing both front brake discs and pads, it was fixed. Damn, the mechanic ripped me off, it cost me over 900. Damn it.
خالد بوتفليقة
خالد بوتفليقة2024-11-16 21:25
It should be the steering gear. I've already replaced two.
فهد بدر الدين
فهد بدر الدين2024-11-11 11:33
The ball joint is damaged, it only costs 60 bucks to replace it.
عمر شفيع
عمر شفيع2024-11-05 21:42
The rubber pad with a ball joint is broken. It's a minor issue, and it can be fixed at the 4S dealership in no time.
خالد أسماء
خالد أسماء2024-09-15 07:44
Check the different ball joints, such as the tie rod end, control arm ball joint, or sway bar link.
نايف عبد الرحمن
نايف عبد الرحمن2024-09-13 17:17
It's probably the steering gear that's broken.
مكرم محمد
مكرم محمد2024-09-13 12:36
Same here, mine makes noise on the left side. I also took out the shock absorber to check, and there was no problem.
I just bought a small Volvo, 2008 model. The condition is pretty good, but the shock absorber springs are too hard. Have any of you experts replaced them, or know which other cars have compatible parts? Thanks!
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
I bought a second-hand 2014 Kia Sportage, and the exhaust smells really bad. I hadn't driven it on the highway before, but a few days ago I did, and the engine warning light came on. The check indicated an issue with the oxygen sensor. After replacing it, the error code was cleared, but a few days later it came on again. It seems fine when not driving on the highway, but as soon as I do, the light comes on and stays on. Can any experts advise on how to fix this issue?
Hey guys, how much does a pair of original V97 shock absorbers cost, and where can I buy them?
I'm considering changing my shock absorbers. Should I go for Bilstein B4 or Tein EnduraPro Plus? Or do you have other recommendations?
Has anyone replaced the shock absorber bushings or other bushings on a 2015 Jetta? As for the engine mount rubber, if it's not severely damaged, should I continue using it?
Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
How much does it cost to replace the front right shock absorber on a 2019 GS5? Should I replace just one or both? 😢
Haval Haval H2
Haval H2AED 54,900Gasoline
