محمد باهر
2024-02-01 22:15
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
Comments( 7 )
خالد فاطمة
خالد فاطمة2024-05-24 10:36
You don't know how to drive; the fuel injection kicks in.
شاكر عبدالله
شاكر عبدالله2024-05-14 06:47
Manual transmission, the gear ratio gap in the 12-speed is too large.
علي سا مرعي
علي سا مرعي2024-04-01 15:03
The coordination of clutch and throttle issue: Mine is a 2015 manual. Why don't I have the situation you're talking about?
نعمان نايف
نعمان نايف2024-04-01 10:19
Congratulations on the genuine product!
عمر عبد الناصر
عمر عبد الناصر2024-03-31 00:37
You'll get used to it.
علي خديجة
علي خديجة2024-02-21 09:00
The gear 1 goes in fine, but gear 2 is always hard to engage.
نايف عبد الوهاب
نايف عبد الوهاب2024-02-11 09:48
The 15 models are the same as above.
What viscosity of engine oil do you use for your new Mazda5? What's your fuel consumption? And does your transmission shift from 1st to 2nd or 2nd to 3rd gear smoothly? I'm experiencing some jerking.
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
I have a question for everyone. I have a 2009 Honda City automatic 1.5. There's some jerkiness when shifting from 1st to 2nd gear, but it's better from 2nd to 3rd. Since it's a used car, I'm not sure how many kilometers it's been driven. Can changing the transmission oil solve this issue? How many liters are needed for a gravity change of the transmission oil?
Is there anyone experiencing a harsh jolt when shifting from 1st to 2nd gear, along with some strange noises? I'd like to ask for solutions. Mine is a 2019 X95. Thanks!
The fuel tank capacity of the 2017 Haval H2 is 55 liters.
Do any of you fellow car enthusiasts feel that the 1st and 2nd gears are noticeably jerky?
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Can the 2017 Haval H2 Automatic Elite be started with a mechanical key?
Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
Haval Haval H2
Haval H2AED 54,900Gasoline & Petrol
