سعود ناصر
2024-04-28 17:42
Haval H2 automatic fashion 2019 model, when pressing the brake, it automatically shifts to neutral and can't shift back. You need to turn off the power and restart to be able to shift. There's no fault code on the screen. Any fellow car owners experiencing the same issue?
I have a 2012 automatic, and it often shifts to neutral when reversing, but there's no issue with driving forward. Has anyone encountered this problem? What could be the issue?
Just had the 2019 automatic Rapid standard serviced and filled up with a tank of gas, then the engine fault code appeared. Has anyone else experienced this?
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
The fuel tank capacity of the 2019 Haval H2 manual Fashion Edition is about 55 liters. What are your fuel consumption rates, everyone?
Why is the engine light on my 2017 Haval H2 Red Label Automatic 1.5T Luxury always on and not turning off?
Can the 2017 Haval H2 Automatic Elite be started with a mechanical key?
What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Haval Haval H2
Haval H2AED 54,900Gasoline & Petrol
