سعود باسم
2024-08-21 10:35
Does anyone know about the Haval H2? Initially, when you pressed once, it would turn off, and pressing a second time would cut off all power in the car. Now, pressing once turns it off, and pressing a second time puts it in a powered self-check mode. Does anyone know what might be the problem? Has any owner experienced the same issue? Thanks!
عمر فاروق
عمر فاروق2024-08-23 12:09
I have a manual transmission like yours. The clutch pedal spring got loose, and the clutch doesn't automatically return to its original position. After parking, I just use my foot to pull the clutch back up, and it's fine. You can try it out. It probably needs a new spring. I'm not sure about automatic transmissions.
When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
Even with power in the battery, my Jinxuan manual sometimes doesn't respond when starting. After turning it on and off a few times, it starts. Does anyone know what might be causing this?
The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
Hello everyone, does anyone know how to modify the daytime running lights to stay on all the time? Originally, the DRLs are on during the day when the headlights are off, but they turn off when the headlights are on at night. I want them to stay on regardless of whether the headlights are on or off.
Can someone please teach me how to disable the sound that occurs once after locking the car, and how to turn off the hazard lights that flash for a period after turning off the engine?
Any brothers know why the car beeps for a few seconds when you turn on the power, but doesn't show any issues or faults?
Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
Haval Haval H2
Haval H2AED 54,900gasoline & Gasoline
