حسين مسعود
2024-02-15 00:28
The "circle A" symbol for the start-stop system on the 2021 GV80's dashboard is flashing continuously, and the RPM won't go above 2500. Pressing the start-stop switch doesn't make any difference. Can anyone help explain what's going on?
محمد صارم
محمد صارم2024-03-11 13:07
How much fuel is left in the tank? Did it just start? I encountered this once, but after restarting, it was fine. It hasn't happened again since I hit 33,000 km. It happened when my fuel tank was nearly empty, and I was climbing out of the underground parking.
عبدالله رائد
عبدالله رائد2024-02-23 18:24
Is the speed also not increasing? I've experienced that too, and it returned to normal after a restart. The tech on my side mentioned it could be due to poor fuel quality. I remember the same issue with the Toyota 8AR engine before; it would show an engine protection warning and reduced power output. Later, I switched to Sinopec, and after driving several thousand kilometers, the issue hasn't occurred again.
حسين جم دين
حسين جم دين2024-02-21 14:52
Accidentally triggered the auto start-stop [shocked]?
خالد أزهر
خالد أزهر2024-02-15 22:45
Ask the 4S store, haven't encountered this situation.
Why does the dashboard keep displaying "Please check the start-stop system"? Does pressing the physical button have any effect?
Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
What does it mean when a yellow exclamation mark appears next to the start-stop light on the dashboard after sudden braking?
My navigation suddenly stopped giving voice prompts. Can someone help explain what's going on?
I have a 2017 New Santana, and occasionally it won't start. If I wait a while or press the gas pedal, it starts. Can someone explain what's going on?
When you enter the GV80 and the driver's seat adjusts automatically, does the buzzing sound continue for a while after it stops moving? Has anyone else experienced this? Thanks.
What could be the reasons for the Peugeot 3008's automatic start-stop function not working properly?
When I start the car, the dashboard shows "Auto Start-Stop Unavailable" and then "Check Engine". What's going on? I just replaced the battery not long ago.
When starting the Santana 1.5 automatic Trendline, the auto start-stop makes a squeaking sound. Does anyone know what's going on? Thanks, everyone!
Genesis Genesis GV80
Genesis GV80AED 300,000 ~ 355,000Gasoline & Petrol
