It would look better if the license plate was placed on the tailgate, making the tailgate design more attractive, and adding a 48V mild hybrid system.
The MG Maxus pickup's tailgate and electric lock are great for when the main cabin doesn't have enough space for your stuff and it takes up passenger space. By adding a rear cover, you can store more items, and the tailgate won't open. Are you also considering installing this rear cover?
When comparing the comfort of the McLaren 720S and the Porsche 911 Turbo S for long-distance driving, it's important to consider a few factors. The 911 Turbo S is generally known for its more refined and comfortable ride, making it a better option for long trips. It often offers better build quality and reliability, which can be reassuring. On the other hand, the McLaren 720S is admired for its striking design and performance. However, it might not match the 911 Turbo S in terms of comfort and ride quality for extended journeys. Ultimately, if exterior design is a priority for you, the 720S is a great choice, but for long-distance comfort and reliability, the 911 Turbo S might be the better option.
4Is it a full hybrid or a 48V mild hybrid?
5It would look better if the license plate was placed on the tailgate, making the tailgate design more attractive, and adding a 48V mild hybrid system.
6Should this plug-in hybrid vehicle have a green license plate or a blue one?
7I hope each model from Hongqi can last longer. I'm planning to buy the HS7 48V Mild Hybrid Qixiang Edition before the end of the year. It won't be discontinued by then, right?
8It's unrealistic to get a 2023 model year 6-seater 4WD Red Flag HS7 with a 2.0+48V mild hybrid for 160,000 yuan.
9I've been following the G80 for a few years now. Has anyone noticed that adding a mild hybrid system to the existing powertrain could make it more competitive? The ES's mild hybrid system really beats other competitors in terms of fuel economy!
10Is the 48V mild hybrid system in the G90 a BSG or an ISG?
