فهد ياسر
2023-09-21 11:58
Hey fellow car enthusiasts, with the 2023 GV80, has anyone experienced the steering wheel not returning to center on its own, needing manual turning back?
سلمان ميرزا
سلمان ميرزا2023-09-30 09:58
It naturally lacks self-centering force, right? After turning, there's some self-centering pull, but you still need to do it manually.
خالد أزهر
خالد أزهر2023-09-23 10:03
You should go back and check it. The steering wheel of this car doesn't have a strong self-centering force, so it can't fully return to its original position. You'll need to manually turn it for the last bit.
خالد عماد
خالد عماد2023-09-21 21:45
You should quickly go to the after-sales service for a check-up. 🌹
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
What causes the steering wheel not to return to center automatically?
Hi everyone, I have a 2017 Murano and noticed that the steering wheel doesn't return to the center after turning. Is this normal for you guys? I just discovered this issue.
Does your Alto automatically return to the center when you turn the steering wheel?
I have a question for the owner of a BYD Song Plus fuel version. Does your car's steering wheel automatically return to the center after you turn it all the way while stationary and then start driving?
Does your car's steering wheel automatically return to center when you make slight adjustments at high speeds? When you make minor adjustments with one hand, do you feel a lot of resistance?
Why is the steering on my 2018 X-Trail heavy and not returning to center automatically?
Hello fellow car enthusiasts! Does anyone else feel that the steering wheel in the 2017 Jetta automatic is particularly heavy? Any solutions to this?
Steering feels stuck and doesn't return to center. How do you guys deal with this? I've heard it can be fixed by reapplying grease to the steering gear. How much does it roughly cost?
Genesis Genesis GV80
Genesis GV80AED 300,000 ~ 355,000Gasoline & Petrol
