The salesperson mentioned that the gasoline version of the GV70 won't be introduced and only the electric version will be available. Is this reliable information? Does anyone know more about this situation? The GV70 is a good car, and if this is their strategy, I'm curious about what Genesis is thinking.
Comments( 11 )
Hello fellow car owners, has anyone picked up a luxury version without the leather seats? I'm curious about the visual effect of the glossy black trim. Could you share some photos for reference? Thanks 😊
You have a 2016 model with a CVT transmission, but you're not sure which version it is. You can usually find this information in a few places: 1. **Owner's Manual**: The manual that came with the car often lists the specific version or trim level. 2. **VIN Number**: Locate the Vehicle Identification Number (VIN) on your car and use it to check online databases or contact the manufacturer for detailed information about your car. 3. **Door Jamb Sticker**: There is often a sticker in the driver's side door jamb that includes details about the vehicle, sometimes including the model version. 4. **Service Records**: Check any service or maintenance records you have for your vehicle, as they might list the specific model version. 5. **Dealership**: Contact a dealership with your VIN number, and they can usually provide detailed information about your car.
To determine whether your Jeep Compass is equipped with an AT (Automatic Transmission) or CVT (Continuously Variable Transmission), you can check the following: 1. **Owner's Manual**: Refer to your vehicle's owner's manual, which should specify the type of transmission. 2. **Vehicle Documentation**: Check any official documents related to the vehicle, such as the purchase agreement or service records, which might indicate the transmission type. 3. **Under the Hood**: Look at the transmission system under the hood. Sometimes the transmission type is labeled on the transmission unit itself. 4. **Vehicle Identification Number (VIN)**: Use the VIN to decode the specifications of your vehicle. Websites or services that provide detailed vehicle information based on VIN can help you identify the transmission type. 5. **Contact Dealership**: Reach out to a Jeep dealership with your VIN. They should be able to provide you with detailed information about your vehicle's transmission type. If there is conflicting information from different sources, the dealership is likely your most reliable source.
4If the car is already started, you can usually drive it even if the key is not inside. However, most modern cars will give a warning sound or display a message indicating that the key is not in the vehicle. This is to alert the driver that the key might be missing. As a chauffeur, if you reach the destination and the owner cannot find the key, it's important to inform them about the situation.
5Is the GV70's all-wheel drive truly full-time, and what is the front-rear power distribution ratio? I've seen some owners say it's not full-time AWD, mentioning that some modes require manual adjustment to four-wheel drive or allow switching to two-wheel drive. I'm a bit confused. Could someone explain the situation with this AWD system and how to use it?
6Can I go to the dealership to ask for a lifetime warranty for the Genesis GV70? I'm worried about the cost of parts in the future, as the original 5-year warranty doesn't seem enough.
7The salesperson said that the BRZ STI version will be introduced in the second half of the year. Is this information reliable?
8Hey guys, is the new 212 reliable or not? Why is there no information about it? The test models online say there will be changes, but I feel the improvements shown so far aren't enough. I really hope it takes off.
9Has anyone actually mentioned the car?! Why haven't I seen any reviews? Even though I'm not buying, I'm still curious to learn about it.
10The Genesis GV70 hasn't been selling in large numbers recently. People are curious about its quality and whether it has many minor issues. It looks quite nice and attractive, but there isn't much real data available on its reliability.
