عبدالله زيد دين
2023-12-11 16:25
Is the GV70's all-wheel drive truly full-time, and what is the front-rear power distribution ratio? I've seen some owners say it's not full-time AWD, mentioning that some modes require manual adjustment to four-wheel drive or allow switching to two-wheel drive. I'm a bit confused. Could someone explain the situation with this AWD system and how to use it?
أحمد صادق
أحمد صادق2023-12-16 10:58
When you visit the 4S dealership and look at the yellow energy consumption label from the Ministry of Industry and Information Technology, if it states "Full-time all-wheel drive," it means the vehicle is always in all-wheel drive mode, regardless of the situation. If it states "Adaptive four-wheel drive," it means that under certain road conditions, the vehicle will switch to 100% rear-wheel drive.
خالد عماد
خالد عماد2023-12-11 22:58
Intelligent four-wheel drive, like starting normally at 50:50, and cruising at 30:70. Different modes also produce different effects, such as normal at 50:50 and sport at 30:70. There are many off-road modes, and it displays the power distribution.
عبدالله نجيب
عبدالله نجيب2023-12-11 19:28
It should primarily be rear-wheel drive with automatic distribution. The central control has a page that uses a bar graph to show power distribution. In comfort mode, the front wheels are sometimes engaged, sometimes not. The manual states that under normal conditions, it's similar to two-wheel drive. 😁 Today it snowed, so I tried the snow mode. From the display, it seems like it's changed to 50:50.
Can a Smart car drive on highways? Some people say it's not allowed, is that true?
How is the McLaren 720s for daily use? Test drives don't really give the full picture. I've seen on TikTok that McLarens often have minor issues. Can any owners share specific problems? Is the suspension safe for speed bumps and underground garages? I'm planning to get one soon. Does the mileage make a big difference? Currently looking at one with 6,000 km and another with 30,000 km.
Hi everyone, for the 2021 Toyota Land Cruiser Prado LTD, how do you switch between high-speed 4WD and low-speed 4WD? When driving in full-time 4WD, do I need to come to a complete stop to switch between high and low-speed 4WD? Thanks!!
Hey guys, how's the rear-wheel drive on this car? Haven't seen any reviews for the luxury rear-wheel drive model online yet. Test drives are only available for the top-tier version. I'm on a budget and torn between choosing leather seats or all-wheel drive.
I am considering purchasing the 2023 GV70 four-wheel drive luxury model. I'm curious to know the real fuel economy from those who have already bought it. Thank you.
I have a used Suzuki SX4 AWD with 130,000 kilometers. In extreme cold weather (minus 40), it drives very steadily. However, when the temperature rises to around 5 degrees above zero, it feels a bit floaty and unstable at speeds of 80 to 100 km/h. Can fellow car enthusiasts offer some advice?
Hey fellow car enthusiasts! I'm driving the BYD Song Plus fuel version and I feel like the steering wheel isn't quite responsive. I've set it to Comfort mode, but it still feels a bit stiff while driving. Could it be that there's some feature I haven't turned off?
I've driven over 50,000 kilometers with the 2.4 AWD version, and I always feel like the feedback from the road is too noticeable when driving on rough roads! It's not comfortable at all. Is it designed this way, or could there be other reasons? Can any fellow car enthusiasts shed some light on this? [Sad][Sad][Sad]
On the day of the Mid-Autumn Festival, the reverse camera and 360 stopped working. I went to the 4S shop the next day for recalibration to fix it. Because the steering wheel was vibrating while driving on the highway, I did a wheel balancing and four-wheel alignment. Today, while driving on the highway, I noticed that the speed range at which the steering wheel vibrates has expanded, and now the seat also vibrates above 124 km/h. Can any expert provide some guidance?
Genesis Genesis GV70
Genesis GV70AED 180,000 ~ 420,000Gasoline & Petrol
