عبدالرحمن ضياء
2023-11-04 09:15
Is the Genesis GV70 engine idle vibration very noticeable? I saw a short video where a bottle of mineral water was placed on the engine, and it moved to the edge and fell over.
Comments( 7 )
عبدالرحمن أمين
عبدالرحمن أمين2023-11-06 11:56
Honestly, no matter how much the engine shakes, as long as the mounting system underneath is well-designed, the car interior won't shake.
محمد بشير
محمد بشير2023-11-05 07:35
There are only 7 comments. Since there is a Genesis salesperson...
حسين سليمان
حسين سليمان2023-11-04 23:02
That's nonsense, I don't feel that way at all.
خالد عماد
خالد عماد2023-11-04 20:07
I haven't noticed it while driving every day, the sound is very quiet. You can try it at the store. 🌹
نايف رضوان
نايف رضوان2023-11-04 13:02
The car's idle vibration is very light.
سلمان عل
سلمان عل2023-11-04 10:53
Why bother? [I want to be alone] There are still diesel civilian cars in Europe, and those things really shake.
أحمد رأس
أحمد رأس2023-11-04 10:19
You'll know once you take it for a test drive.
I saw a video on TikTok about the Genesis 4S, saying the new model will switch to a 2.5T engine. Why haven't I seen the 2.5T?
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
When driving the Tiida, there's always a rolling sound like a water bottle moving back and forth, but there aren't any bottles with liquid inside the car. What could be causing this?
Choosing between the G80 and the XFL depends on your personal preferences and needs. Here are some things to consider: 1. **Brand and Model**: - G80 generally refers to the Genesis G80, a luxury sedan known for its comfort and advanced technology. - XFL typically refers to the Jaguar XFL, which is the long-wheelbase version of the Jaguar XF, offering more rear-seat space and luxury features. 2. **Performance**: - Consider the engine options and horsepower each model offers. The G80 might offer a more powerful engine, while the XFL might focus on a balanced ride. 3. **Features**: - Look at the features each car offers, like the infotainment system, loudspeakers, safety features, and interior quality. The G80 is known for its tech-savvy features, while the XFL may emphasize luxury and style. 4. **Fuel Economy**: - Check the fuel economy for both. If fuel efficiency is a priority, this might influence your decision. 5. **Comfort and Space**: - If rear-seat space is important, the XFL might have the edge due to its extended wheelbase. 6. **Budget**: - Consider the price and what fits better within your budget, including maintenance costs. Ultimately, test driving both and considering these factors could help make your decision easier.
Genesis Genesis GV70
Genesis GV70AED 180,000 ~ 420,000Gasoline & Petrol
