علي عوض
2024-10-26 15:34
Can anyone provide detailed information on the front and rear bumper beams of the GV70, as well as the materials used in the body?
خالد عماد
خالد عماد2024-10-26 22:10
If you're concerned about safety, you can check the EU crash tests. 🌹
Looking to buy a left front door for a 2007 FJ. Can anyone in the car community provide information on where I can find one? 🙏🙏
Hey everyone, where can I buy modified front and rear bumpers for a March? 🙏🙏
You have a 2016 model with a CVT transmission, but you're not sure which version it is. You can usually find this information in a few places: 1. **Owner's Manual**: The manual that came with the car often lists the specific version or trim level. 2. **VIN Number**: Locate the Vehicle Identification Number (VIN) on your car and use it to check online databases or contact the manufacturer for detailed information about your car. 3. **Door Jamb Sticker**: There is often a sticker in the driver's side door jamb that includes details about the vehicle, sometimes including the model version. 4. **Service Records**: Check any service or maintenance records you have for your vehicle, as they might list the specific model version. 5. **Dealership**: Contact a dealership with your VIN number, and they can usually provide detailed information about your car.
To determine whether your Jeep Compass is equipped with an AT (Automatic Transmission) or CVT (Continuously Variable Transmission), you can check the following: 1. **Owner's Manual**: Refer to your vehicle's owner's manual, which should specify the type of transmission. 2. **Vehicle Documentation**: Check any official documents related to the vehicle, such as the purchase agreement or service records, which might indicate the transmission type. 3. **Under the Hood**: Look at the transmission system under the hood. Sometimes the transmission type is labeled on the transmission unit itself. 4. **Vehicle Identification Number (VIN)**: Use the VIN to decode the specifications of your vehicle. Websites or services that provide detailed vehicle information based on VIN can help you identify the transmission type. 5. **Contact Dealership**: Reach out to a Jeep dealership with your VIN. They should be able to provide you with detailed information about your vehicle's transmission type. If there is conflicting information from different sources, the dealership is likely your most reliable source.
How much can I get a 2016 white V40 1.5T base model with 80,000 km on it? The front and rear bumpers have been repainted. [Crying]
Does anyone know where I can buy a used front bumper headlight for a Phaeton?
Is it illegal to modify the front and rear bumpers of a GLS to Maybach style?
Does anyone know the strength in megapascals of the steel used for the front and rear bumpers of the Xpeng, and the strength of the steel for the A, B, and C pillars? Thanks a lot.
What are the original floor mats like in the 2024 Alphard? Why are the materials for the front and rear seats completely different, and why is there no logo on the rear floor mats?
I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
Genesis Genesis GV70
Genesis GV70AED 180,000 ~ 420,000Gasoline & Petrol
