Will the car scrape the bottom when going down to the basement?
Is there a squeaking sound when the windows of your new car go up and down in the rain? Does everyone experience this?
Can this car be driven on the road when the roof is down?
4How do you guys drive into underground parking lots? I bought a car and realized it scrapes the bottom when I go down. 😢
5Can a Supra chassis go down into a basement garage? 🌹🌹
6When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
7There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
8Where is blocked if water leaks from the bottom of the A-pillar during a car wash?
9Do you guys often scrape the chassis when driving? Is it necessary to choose a front axle lift?
10How's the ground clearance of this car? My current ES always scrapes the speed bumps when I drive to the industrial area. Is this one any higher?
