سلمان أنس
2020-06-12 09:23
Why does the MG GT's air conditioning only blow towards the front windshield, and the other direction buttons don't work? What could be the reason?
Comments( 7 )
عبدالله أرسلان
عبدالله أرسلان2022-03-22 21:10
Disconnect the battery for a minute or two, then reconnect it, and it should be fine.
عبدالله لبيب
عبدالله لبيب2022-03-22 16:51
After taking apart the center console, unplugging the wires and plugging them back in fixed the issue.
عمر فخر دين
عمر فخر دين2021-12-11 14:52
Mine too [tears]
همام أحمد
همام أحمد2021-12-11 00:17
The wind direction motor is broken on mine too, but you can replace it without removing the dashboard.
حسين أكرم
حسين أكرم2021-03-25 22:26
I have the same issue with my Rui Xing GT. The repair shop said it's the throttle switch that's broken. I don't get it. They also mentioned that they need to lift the dashboard to fix it.
علي حازم
علي حازم2020-06-21 22:53
The air conditioning control board is broken, and I've also been impacted once. It's still under warranty.
سلمان بهاء الدين
سلمان بهاء الدين2020-06-12 10:19
We usually only press the button for the front defogger when there's fog on the windshield. If you want to change the airflow direction, you can press other buttons to redirect the airflow (like face or feet). If pressing the button doesn't work, it might be a malfunction, and you may need to check the circuitry.
The rear air conditioning vents are not blowing cold air?
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
What could be the reason that the MG ZS won't start with the push button?
Is it worth buying a 2011 automatic high-end 1.5 with 110,000 km for 18,000? The front windshield has been replaced, and the rear air vent can't blow warm air. I didn't look into other details. I took a short drive and didn't notice anything unusual.
What could be the reason that the air conditioning in my 2011 Phaeton blows cold air before hitting the highway, but gets warmer the longer it runs?
Why does the air conditioning blow cold air while driving, but not when stopped at a traffic light?
Is the warm air blowing on the windshield of your LC120 also weak?
Is the warm air blowing on the windshield of your LC120 also feeling weak? Is it the same for you guys?
MG MG GT
MG GTAED 61,900 ~ 77,150Gasoline
