Why does my car window go down but not come back up, and I have to press the unlock button repeatedly to open it? [Facepalm]
Why do you have to press the rear window button once before starting the 2013 GS5?
My sunroof won't open, what's going on? I press the button, but there's no response at all.
The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
4Hey guys, does anyone know why the trunk can be opened with the key but not by pressing the button?
5Does anyone know why the rear window won't go up or down? Thanks!
6Fellow car enthusiasts, does your 2018 manual comfort model have the feature to lower the windows by long-pressing the unlock button on the key?
7Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
8Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
9The fuel tank switch is pressed down and won't pop back up. How should I handle this?
10How to set up the Ariel so that the front passenger or rear passengers can open the door without the driver needing to press the unlock button? Please help!
