سلمان جواد
Oct 7
What is the recommended tire pressure for a GTR?
فهد عماد2022-06-19 19:38
I usually go for 2.5 [grin]
سلمان ربيع2022-04-15 20:33
2.3-4 is about the same.
حسن سعد2020-10-07 04:41
The normal tire pressure should be maintained between 2.2 and 2.5. The pressure difference between the four wheels should not exceed 0.2. If the weather is quite hot, the tire pressure can be slightly lower. Both too low and too high tire pressure carry certain risks.
Tire pressure warning
How to reset the tire pressure on an F150 after patching the tire? [what][what]
4What is the optimal tire pressure for a Patrol?
5How to reset the tire pressure?
6Could someone tell me the recommended tire pressure for this car? I accidentally removed the label, so now I'm not sure what the right pressure should be. Thanks in advance! 🙏🙏
7The tire pressure monitoring sensor is broken.
8The tire pressure is fine, but the tire pressure light came on this time it snowed. What's going on?
9How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
10How to reset the tire pressure?
