عبدالله ميك
2023-04-26 10:37
I feel like the brakes on the McLaren GT are really stiff. Is it possible to modify them later to make them softer? [Facepalm] After being stuck in traffic for half an hour, my right leg is sore. Also, how do you judge the distance on both sides of such a wide car? Every time I drive on narrow roads, I'm terrified of scratching it...
حسين مبارك
حسين مبارك2023-04-27 10:53
You'll get used to it. Our brakes are a bit stiff. 😁
حاتم سلمان
حاتم سلمان2023-04-26 23:55
All McLaren models have hard brakes, which seems unchangeable. However, once you get used to it, it doesn't feel that hard anymore.
Model X, 40,000 km. There's a consistent humming noise from the rear wheels while driving, most noticeable at speeds of 35-40 km/h. You can feel a slight vibration in the floor when sitting in the back seat. I've been to the dealership a couple of times for this, and the last time, the technician confirmed the noise. After checking, they said the half axles are fine and concluded it's due to tire aging. I've heard that 21-inch tires tend to wear unevenly and might need replacement around 40,000 km. The tires only have 40,000 km on them, and the tread still looks clear. Is this really possible?
In the 2019 JETOUR X90 Enjoy Edition 6-seater with a 6DCT dry dual-clutch transmission, currently at 120,000 kilometers, an issue has been occurring since around 90,000 kilometers. When starting the car cold, everything is normal during acceleration. However, after driving for about half an hour and the engine warms up, when stopping or waiting at a traffic light and then trying to accelerate again, the car doesn't respond to the throttle. If you press the throttle harder, the engine stalls. When you feel the engine shake while pressing the throttle, if you release the pedal immediately and then press it again, the car can start moving, and everything works normally after that. There are no fault codes detected by the computer, and the spark plugs have been replaced. The engine checks out normal at the 4S shop. I'm seeking advice from experts on how to resolve this issue or if any fellow JETOUR X90 owners have experienced a similar problem and how they got it fixed. Thank you very much for your help!
McLaren McLaren GT
McLaren GTAED 850,000 ~ 876,950Gasoline & Petrol
