How do you install the gear shift knob on the Roewe?
How do you remove the gear knob from this car? I want to replace it with a new one.
Gear knob light not working on the 150, any ideas? Thanks.
4Hey guys, I have a 1.6 manual Liana. At what RPM do you usually shift gears?
5Has anyone replaced the gear knob of JETOUR X95 with a crystal one?
6I'm looking for some guidance on how to replace the gear shift knob on a 2017 GAC GA8. If anyone knows, please share. Thanks a lot!
7To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
8Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
9Which mode do you use for highway driving in the 2022 Roewe RX5 Max?
10How do I shift gears when driving a Setus down a long slope?
