How do you guys change the transmission oil for your Ruixing? I changed my transmission oil at 200,000 km, and now it's almost 260,000 km. When I accelerate at low RPMs, there's a noticeable jerk and drag, like it's getting stuck.
Do you experience jerking with your S40? After repairing the oil leak on mine, the low-speed jerking became very severe. I spent 7000 to repair the transmission, but there's still slight jerking. When starting, it jumps to 3000 rpm and then drops to 2000 rpm, with a fuel consumption of 15. I've already spent 10,000, and people say it's an old car, so it's normal. I'm wondering if you guys have experienced this situation!
Is the jerking in the 13 model caused by needing a transmission oil change? I've never changed it in over 90,000 kilometers. 🤦♂️
4Should I change the transmission oil for my 2012 Yizhi? It's almost 70,000 kilometers! Recently, I've been feeling some jerking while driving.
5Has anyone changed the transmission oil?
6Should I change the transmission oil for a 2019 GAC GS5 270 Premium Edition with 60,000 km?
7Is it necessary to change the transmission oil if there's occasional delay and jerkiness when shifting at 35,000 km over 3 years?
8If you have purchased a second-hand 2009 Peugeot 307 sedan with a 1.6 automatic engine and it has run 150,000 kilometers, and you notice that it runs at 3300 RPM at 120 km/h on the highway, you might want to consider changing the transmission oil. It's generally a good idea to check the maintenance history of a used car and ensure that essential fluids like transmission oil are fresh, especially if you are experiencing high RPMs.
9When slowly accelerating at low speeds, the V60 B4 2024 model experiences noticeable jerking and dragging.
10When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
