How do I turn off the 360 panoramic image that pops up on the central control when turning?
How do I set up the compass on the 2014 navigation model? I can't find the setting option. I switched to a big screen 360. Could the change in the central control be causing the compass to malfunction? Please let me know how to set it up.
The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
4The 360-degree image is a bit blurry, how to fix it?
5Hey guys, how do you set up the automatic unlock when the engine is turned off for the 2019/2020 automatic elite version?
6The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
7How do you turn the headlights on and off?
8While driving, the central control screen suddenly went black, then restarted after two to three minutes, followed by a "pop" sound. Any ideas?
9How to set up 360-degree imaging to display when turning left or right?
10How do I turn off this central control screen? Looking for expert advice. 😭
