فهد محمد
فهد محمد
Dec 1
When I put it in D gear and release the brake, sometimes it moves forward, and other times I have to press the accelerator for it to move.
عبد العزيز صعب
عبد العزيز صعب2024-12-02 00:10
Is the auto hold feature turned on? Just turn off the auto hold feature.
عبدالرحمن جل
عبدالرحمن جل2024-12-01 09:16
Remember to gently tap to release the auto hold, and be careful to press the pedal deeply to prevent the car from lurching forward.
خالد تركي
خالد تركي2024-12-01 02:06
The pressure you apply to the brake pedal affects the automatic parking system in the car. When the green "P" symbol appears on the dashboard, it means the brake is engaged. If it doesn't show, it means the brake isn't engaged, and the automatic parking isn't activated. Check the manual for more details!
حازم سعود
حازم سعود2024-12-01 02:06
You have activated the auto hold, right? When you're in Drive (D) and press the brake fully, it will engage the auto hold. At this point, releasing the gas pedal won't make the car move. You just need to press the gas pedal again, and it will automatically release the hold and move forward. This feature is useful for when you're waiting at a red light.
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
Hello everyone, I'd like to ask something. When I cold start my car, the idle speed is quite high and when I release the brake, the power is strong and it just surges forward. But after driving for a few minutes or waiting at a few traffic lights, it starts to lose power. When I release the brake, it moves very slowly, and it only gets a bit better if I press the accelerator. It's a 2007 model with an automatic transmission.
Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
Why does the car not move when I put it in gear, but only moves when I accelerate?
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
When you shift to D gear and press the accelerator to start, does your car make a buzzing sound, like exhaust resonance?
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
GAC GS3
GAC GS3AED 65,000 ~ 99,800 Petrol & Gasoline
