حسين نجيب
Dec 1
Have you noticed that the low beams have a very short range? On roads without streetlights, when the automatic high beams are turned on, they turn off as soon as there's an oncoming car, and the low beams make it hard to see the road just 3 meters ahead.
Hi guys, does the 2017 GS7 1.8T have halogen bulbs or xenon bulbs for the low beam headlights?
As long as the Ford F-150 Raptor is not in the "P" (Park) position, the low beam lights turn on. What's going on?
Why do the low beam lights on the Ford F-150 Raptor turn on in all gears except for park?
4Has any 80 owner adjusted or upgraded the high beam distance? Can the service center do it? The illumination is really too short, can't see the road at all at night. [Facepalm][Facepalm][Facepalm]
5How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
6How is the EX30's lighting performance at night on roads without street lamps? Are there any real owners who can share photos of the high and low beam effects during the day and night? Ideally, it would be best to find a completely dark road to see the effect at its best. Thanks in advance!
7Does the 2019 Ford Territory's instrument panel show when the low beam is turned on?
8Has anyone changed these two lights? The LED headlights are hard to see the road with in the rain at night.
9Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
10I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
