سعود نور
2023-10-26 11:33
Why does the electronic brake on the MG GS get damaged when you press the brake pedal to release it?
Will the brake lights illuminate during regenerative braking when you are not pressing the brake pedal?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
Hey guys, when the car is off, should the brake pedal get harder the more you press it? My other two cars are like that, but the Patrol isn't as obvious, feels a bit soft. I changed the brake fluid last year, kind of worried. Is it the same for you? Thanks.
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Is it normal for the Haval Jolion Comfort edition to lurch slightly when you park on a slope, shift to P, engage the electronic handbrake, and then release the foot brake?
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
