Where is the MG GS outdoor temperature sensor located?
Car enthusiasts, is it normal for the dashcam of the 2017 MG GS 1.5T Deluxe version to flash red and blue lights?
Why does the electronic brake on the MG GS get damaged when you press the brake pedal to release it?
4Where is the key sensor for the GA8 located?
5How did you deal with the issue of the water temperature sensor malfunctioning and the temperature light constantly flashing? I replaced the temperature sensor, but it started flashing again after two months. Did you replace the thermostat assembly? 2017 model.
6Car enthusiasts, for the 2017 MG GS automatic, which brand of transmission oil would you recommend?
7How to reset the tire pressure on the MG GS 4WD?
8Is the AC not engaging related to a damaged outdoor temperature sensor? My external temperature sensor shows a dash.
9Where is the car key sensor located?
10Where is the oxygen sensor located in a KAMIQ?
