MG GS, with over 60,000 km, recently having trouble starting the car. It requires several attempts to start. Once started, five or six warning lights come on, and when pressing the accelerator, the car doesn't move, can't go over 10 km/h. It often needs to be turned off or re-shifted. Sometimes while driving, pressing the accelerator doesn't speed up the car, but the engine sounds like it's in neutral. It also jerks when moving. Local repair shops are hesitant to fix it, and the 4S shop is too far away. I'm worried the car won't accelerate on the road, which could lead to an accident. Seeking help.
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
The GA8 often has trouble starting and requires several attempts. How can this issue be resolved?
4Hey car enthusiasts, have you ever experienced a jerky start, where you accelerate but the car doesn't move immediately, and then suddenly jumps forward after a few seconds?
5When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
6There's no local 4S shop, and the nearest one is over 200 kilometers away. I want to ask, if I encounter a traffic accident and want to go to the 4S shop for repairs, is it not possible? Thanks.
7I have a 2016 Honda City, and sometimes it doesn't start on the first try, but it starts on the second attempt. Experts, what could be the problem?
8I just received the news that the local 4S shop has closed. I want to ask, for car owners without a local 4S shop, how do you handle regular maintenance? Do you have to go to another city for the 15 maintenance services over the 5 years for a new car?
9Why does it take two or three attempts to start the car?
10My car is a 2.0 naturally aspirated engine. When I gradually accelerate past 80 km/h, the car shakes a few times, and then it stops shaking. However, if I press the accelerator hard, this doesn't happen. I wonder what's causing this.
