سلمان منصور
2023-11-10 01:29
For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
خالد صارم
خالد صارم2024-01-09 12:26
The airflow of this car isn't strong, but the cooling and heating effects are decent. If you want more airflow, set the vent to blow directly at you!
How did you solve the issue with the rear central air conditioning since the NV200 doesn't have central air conditioning?
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
How to remove the air conditioning vent louvers?
Is there any modification available for the central control and air conditioning knobs? The original ones don't look good.
Is everyone's air conditioning vent working fine? I feel like there's not much airflow to my feet...
Is anyone else experiencing an issue with the footwell air vent on the Aion? Even after turning off the footwell vent on the control panel, cold air still blows on my ankles. It's really uncomfortable on a long drive. Anyone else having this problem?
The air conditioning was set to level 4, but there was still barely any cold air and the airflow was very weak. What's going on? After a day, it went back to normal. It's really frustrating.
Hello everyone! Is it common for the rear air vents in the Outlander to have low airflow?
