نايف شادي
2024-11-30 12:46
The foam between the dashboard and the windshield is visible. Is it necessary to add a seal strip? It feels like the gap is too wide.
I've been hearing a strange noise from the left side of the dashboard when I press the accelerator in the morning. It feels like a vibration. Have any of you experienced something similar? I'll upload a video next time.
I feel like the stock steering wheel position of the March is too high, and I want to adjust it lower but can't find the mechanism. Where is it located?
The steering wheel is really sensitive... There's no resistance when you turn it slightly left or right, it's like steering an air wheel [facepalm]. You only feel resistance after that gap! You really have to hold it with both hands when driving on the highway!! [facepalm][facepalm] Do you guys experience this too?!!
Can you adjust the angle of the rearview mirror on the Geely? It feels like it's tilting too low... Or can it be set to tilt on one side only?
The dashboard lights keep staying on after turning off the engine recently, and I can't lock the car. Then, when trying to start again, it takes three or four tries to get it going. After starting, the dashboard lights come on again. When the dashboard lights are on, pressing the remote to lock the car doesn't work at all. Locking the car feels like a lottery every time.
When driving at low speeds over rough roads or speed bumps, and then accelerating, the RPM between 1100 to 1500 feels like it's cutting out. Once the throttle picks up, everything returns to normal.
Does anyone else experience wind coming through the headliner when the AC is on (especially when the fan speed increases)? I can feel a noticeable draft when I touch the driver's side seal. There's also a whistling sound when the windows are closed. Is there a car owners' group? I'd like to join.
I want to ask real car owners, besides the difference in power and the various driver assistance features, is there any difference in the chassis driving feel between the 2.0 and 3.0? I noticed the tires are different too, one is 255 and the other is 285.
Does the 3.0 Rui Enjoy have L2? It seems like if it just adds rear-wheel steering for an extra 100k, then it might not be worth upgrading to the Rui Zun. Is it necessary to spend more for the Rui Zun?
GAC GAC GS8
GAC GS8AED 145,982 ~ 179,999Gasoline
