Hey fellow 2025 GWM GS8 owners, have y'all experienced issues like the system freezing, screen flickering, rebooting, or crashing? I'm planning to buy one, but the online cases are kinda worrying.
Comments( 8 )
Hey fellow car owners, does the 07 Lexus IS 250 (low trim without screen) have a BLIS system? Also, is there a USB port, and where's the cigarette lighter located?
Will upgrading the system fix the freezing of the central control screen in the 2023 X90 Zilong Changsheng 7-seater?
4Hey fellow car enthusiasts, my car is over seven years old and I haven't changed the tires yet. It's only been driven 60,000 kilometers. The tires are slightly aging, but I haven't driven much in recent years. It's mostly parked in the basement, so it's rarely exposed to the sun. Should I change the tires? I'm planning a long trip and am a bit worried!
