Can the high beams be modified?
How do I turn on the high beams?
How to turn on the high beam headlights?
How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
4Has anyone modified their headlights? The high beams feel so weak, it's like there's no difference whether they're on or off. [Shocked]
5How can I adjust the high and low beam headlights inside the car?
6Does anyone know why the high beam and low beam headlights keep breaking?
7Has any car owner modified the headlights? I asked at the shop and they said it needs to be changed to 16 lenses, 8 for low beam and 16 for high beam. I haven't seen any examples of such work, so I didn't dare to modify it easily. [Facepalm]
8The high beams of the car are not illuminating the road but are pointing to the sides. What could be the problem and how can it be fixed?
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
