عمر بدر
2023-01-25 08:26
Woke up one night! Went outside and found all four car windows and the sunroof open! Have any of you ever experienced this situation?
فهد فادي
فهد فادي2023-09-23 13:18
How to solve it? I've encountered this once.
خالد فاطمة
خالد فاطمة2023-09-08 15:10
Yes, many times.
مأمون سلمان
مأمون سلمان2023-01-25 23:17
I want to be alone.
Why does my car window go down but not come back up, and I have to press the unlock button repeatedly to open it? [Facepalm]
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
Why did all the windows and sunroof open automatically? I've experienced this once.
My sunroof won't open, what's going on? I press the button, but there's no response at all.
Are there any owners of 2019 two-wheel drive or four-wheel drive luxury models here? I have a question. For models where only the driver's window has the one-touch up/down feature, can you long-press the lock button on the key to raise the windows? Can this be upgraded at the dealership? My 2019 four-wheel drive luxury model can only close the sunroof with the key, not the windows.
I'd like to ask fellow car enthusiasts a question. For the 2020 4WD Elite Edition Jeep Compass, is there a button inside the car to open the trunk? I've been opening it from the outside directly for four years. Does anyone know?
I saw a sedan on the road, but when I looked it up, all I found was "wagon"?
When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
The outside temperature is 15 degrees Celsius, but it's hot inside the car without opening the windows. What's going on?
