Why did all the windows and sunroof open automatically? I've experienced this once.
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
Why does my car window go down but not come back up, and I have to press the unlock button repeatedly to open it? [Facepalm]
Have you experienced any sunroof leaks with your Jeep Liberty? How did you resolve the issue?
4Woke up one night! Went outside and found all four car windows and the sunroof open! Have any of you ever experienced this situation?
5Hello everyone, has anyone experienced this with the 2019 model 35p automatic? Currently, I've driven 60,000 kilometers, and occasionally when I brake at a red light, the idle speed fluctuates. How did you deal with it? I've cleaned the throttle and replaced the spark plugs, but I still don't know why it's happening.
6Why did all the windows and sunroof open automatically? I've experienced this once.
7Why do you have to press the rear window button once before starting the 2013 GS5?
8My sunroof won't open, what's going on? I press the button, but there's no response at all.
9Why won't the car sunroof open?
10When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
