There have been heavy rains these past few days, and the driver's side is leaking, with the A-pillar being wet. Could it be that the sunroof is blocked? Or is there another reason?
There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
During the rainy season, my car has been parked outside for the past few days. After starting the car and pressing the brakes, I hear water sounds from the chassis. I've checked the sunroof and there's no leak, also tested the floor, and it's fine. Could it be that the frame has taken in water? Can any expert analyze this?
4I've been having heavy snow here the past couple of days. The car starts to skid once the speed goes over 20. Neither the snow mode, standard mode, nor sport mode seems to work. How about you guys?
5Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
6Where is blocked if water leaks from the bottom of the A-pillar during a car wash?
7Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
8What's going on with the Skoda Kodiaq A-pillar leaking water when it rains?
