نايف فاتح
2022-08-01 13:56
My GAC GS7 has only run 55,000 kilometers, and the turbocharger fan is already broken. The repair shop said it might just be a one-time issue! Have you encountered anything like this?
My car has only run over 50,000 kilometers, and there is an abnormal noise when starting the engine cold. After checking at the 4S shop, it was found that the intake camshaft timing is delayed and there's a fault with the VCT. The repair costs over 20,000. Has anyone encountered this situation before?
The oil light came on while driving the 2012 XV at high speed. I went to the repair shop, and they said it's burning oil. What should I do?
Can a 2009 Peugeot 307 hatchback automatic with 150,000 km go on the highway? I asked the repair shop, and they said it's okay for short distances, but not for long trips.
There's no local 4S shop, and the nearest one is over 200 kilometers away. I want to ask, if I encounter a traffic accident and want to go to the 4S shop for repairs, is it not possible? Thanks.
My car was registered in 2018 and has just over 10,000 kilometers. It's been in the repair shop for half a month now. They said it's the electronic rocker arm that's broken. First, they tried replacing the spark plugs, but that didn't work. The ignition coil didn't work, and neither did the injectors. Then they said it's the electronic rocker arm. Wow, it costs 12,000. Sigh, they suggested I replace the engine, which is around 15,000. I don't even know what to do. This car isn't worth 50,000 now, and fixing it costs over 10,000.
I bought a 2017 V40 and recently the engine sounds like a tractor when running. Does anyone know what might be going on? The repair shop said it might be a cylinder scoring issue, but they're not sure.
Fellow car enthusiasts, my GS5's central control screen keeps rebooting. The 4S shop said the main unit is broken and it would cost 6k to replace it. [Facepalm] Has anyone else encountered the same issue? Is it possible to repair it?
The daytime running lights on the 2020 model can't be turned off unless the engine is off. Has anyone gone to a repair shop for modification?
Has anyone encountered cracked door handles on a 20-year-old Cayenne? The 4S shop refuses to repair them under warranty because it's expired. What should I do?
