Is it normal for the radiator fan to keep running after turning off the engine when driving four to five kilometers in the city with the current weather?
I've been having a headache with my Volvo S80 2.5T. After replacing the radiator, the upper hose has come off three times, and then the lower hose came off once. Does anyone know what could be the reason? The water temperature has been normal, no overheating, and the fan is working fine.
What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
4Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
5Is this car currently allowed on city roads domestically? If it can be, I'll keep waiting for mass production. 🤔
6What could be the issue if the radiator fan of the Haima S5 only operates when a blower is used, and doesn't turn on even after driving for a long time?
7My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
8Can daytime running lights be turned off?
9When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
10Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
