Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
Is there anyone who has changed the rear shock absorbers because of abnormal noise and excessive stiffness?
4I'm considering getting a 2017 GS7. Does this model have any common issues? [shocked][shocked][shocked]
5Is the constant feeling of bumpiness due to an issue with the shock absorbers?
6Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
7Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
8Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
9How much does it cost to replace the front right shock absorber on a 2019 GS5? Should I replace just one or both? 😢
102018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
