I have a 2018 GS7, and the engine vibrates a bit when idling. There's also a slight ticking noise when driving, which started recently. Can anyone help me figure out what might be causing this?
When driving over 120 km/h, the steering wheel and accelerator cause numbness in my hands and feet due to vibrations. Even slight unevenness on the highway results in rhythmic vibrations, making my hands and feet feel numb.
What could be causing severe idling vibration?
When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
4I have a 2018 GS7, and the engine vibrates a bit when idling. There's also a slight ticking noise when driving, which started recently. Can anyone help me figure out what might be causing this?
5My 2018 car's engine has started making a ticking sound recently. What's going on?
6I've got a 2018 GWM GS7, and recently the engine's been making a "da-da-da" sound while driving. What's going on?
7Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
8Is it normal to feel slight vibrations when sitting inside a Patrol 4.0 at idle?
9When starting a cold car, the idle speed takes 5-6 minutes to drop below 1000 RPM, and the engine vibrates. I thought the throttle was dirty, cleaned it, but it didn't help. The oxygen sensor current shows -0.01 mA. The repair shop says it's fine, but I feel like there's an issue. What could be causing this?
10What could be causing the severe idling vibration in the x95? It's at 5.5 kilometers. How can I resolve this issue?
