How to turn off and on the auto start-stop feature for the 2017 320 Smart Connect version?
What could be the issue if the auto start-stop feature on a 3.0 Grand Cherokee hasn't worked since I bought it less than a year ago?
How do I turn off the auto start-stop on the ILX? 😅
How do I turn off the engine start-stop system?
4How do I disable the automatic start-stop function on the 2016 Peugeot 508, guys? Every time I start the car, I have to manually turn it off.
5Does the 2021 Fengxing T5 EVO have an auto start-stop feature? It seems like it doesn't, but I'm not sure. I need to change the battery, but I'm not sure if it has the auto start-stop function.
6How do I disable the auto start-stop feature on the 2015 Subaru Outback?
7After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
8The battery couldn't start the car after 3.5 years and needed replacement, even though the auto start-stop feature was mostly off. Fellow car enthusiasts, when did you replace your battery for the first time?
9I've had my car for over a year, and the auto start-stop has never worked. I went to the dealership, and after a test drive, the service staff said it works, but I need to turn off the AC for it to function. I've turned it off, but it still hasn't activated. How do you guys use it?
10Where is the auto start-stop switch for the Jetour X90 PLUS?
