أحمد سليمان
2024-11-20 07:59
Hey folks, my GS7's reverse lights aren't working. What's the issue? No power in the wiring?
How to deal with the issue of the reverse camera not responding on a 2005 Nissan Bluebird after starting, and where to connect the wiring?
Hey folks, the cigarette lighter below the center console in my Sportage has power, but when I plug in the car charger, there's no response. The charger is good. What's the issue?
Hey folks, my headlights work during the day but not at night. Has anyone encountered this issue before? Help needed!
Left reverse light not working?
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
The wipers aren't working, no response at all. What's the issue? I've only driven 7,000 kilometers.
Hey Alto friends! After I connected the reverse radar wires myself, the car started twice without any issues. But after I arranged the wires, it won't start anymore! Does anyone know what might be causing this?
Hey folks, which is better: purely fuel-powered, hybrid, or range-extended vehicles?
Hi guys, my 2014-2015 old Skoda Rapid's headlights aren't working. How did you guys solve this issue? Any good suggestions?
Hey folks, my 2014 Haval H2 makes a buzzing noise when I turn the steering wheel all the way while reversing. What's going on?
