أسماء فهد
2024-11-20 16:14
Does anyone know why the GS7 battery runs out of power in just one week? What could be causing the battery drain? [Praying][Praying][Praying]
What to do if your car runs out of power on the highway?
My GAC GS7 has only run 55,000 kilometers, and the turbocharger fan is already broken. The repair shop said it might just be a one-time issue! Have you encountered anything like this?
Has there been a situation with your JETOUR X70 where the battery runs out of power even before reaching 500 kilometers?
Does your car battery often run out of charge?
If you leave your car key (spare key) inside the car, it runs out of battery in just one afternoon.
Hey car enthusiasts, just wondering, will the car give a warning to replace the key battery before it runs out?
How long does everyone's car battery last? Mine only lasts about two years before it runs out. Does the start-stop function consume that much power?
Does your key run out of battery every two years?
If you left your car in D gear overnight and found it without power the next morning, it could be due to the battery being drained. Does anyone know why this happened?
