حسن قربان
2022-07-13 09:01
Does anyone else have a noise issue with their sunroof? My 2018 car has a serious noise problem at the rear on the passenger side. 🤦‍♂️🤦‍♂️🤦‍♂️
محمد مصطفى
محمد مصطفى2022-10-01 23:49
I also bought mine in 2018, but I've only opened the sunroof once when I got the car, and never used it again.
خالد مراد
خالد مراد2022-09-26 12:34
2018 model car, making annoying noises [I just want some peace]
محمد صارم
محمد صارم2022-08-08 11:59
Just add some hair oil, and it'll be fine.
فهد أنور
فهد أنور2022-08-04 15:54
Not found.
خالد خضير
خالد خضير2022-07-22 18:13
You'll get used to it.
Does anyone else's car make strange noises inside? My car always has these noises, but the dealership can't find the problem!
Passenger side rear footwell is mysteriously accumulating water, while the other three spots are dry. The headliner is also normal with no water stains. It's just the passenger side rear that's wet! Can anyone help me figure this out?
After reaching a speed of 60, there is a constant hissing sound from the right rear side in my Arrizo 3. Is this due to wind resistance caused by a design issue, or could it be something else? Has anyone else experienced this problem?
When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
Hey everyone, does anyone else have strange noises coming from the front passenger seat or the trunk? 🤔
Does the 2017 Santana with a 1.4 engine have a loudspeaker on the passenger side? My passenger side got wet, and I'm not sure if there was a loudspeaker there originally.
Does your SUV make a buzzing noise from the rear passenger side when driving at speeds of 20-30 on bumpy roads? There's no such sound from the driver's side. Without some music, it's really hard to ignore that noise!
Is sunroof leaking and rear door handle not retracting a common issue?
How to fix the sunroof noise issue?
