Why is the stability control light on and the handbrake not working? Anyone else experiencing the same issue?
Is it normal for the Skoda Rapid's central control screen to freeze under high temperatures? It works again when the temperature drops. Does anyone else have the same issue?
Is there anyone else experiencing unresponsive buttons on the 2016 model's central control screen?
Has anyone else experienced this? Is it just me or is it a common issue?
4Neither CarLife nor CarPlay is working on your phone. Has anyone with the same model from 2017 experienced this issue before, when it used to work fine?
5Why does the brake pedal on the JAC Shuailing T8 not return to position? It works fine when I lift the brake pedal with my foot. What's going on? Does anyone else have the same issue?
6I have a 2019 GS5 Elite version. Sometimes the central control screen doesn't power on, but the air conditioning works fine. The reverse radar is not usable, and the central control screen doesn't light up. Does anyone know why this is happening or has anyone else encountered this issue?
7Why is the stability control light on and the handbrake not working? Anyone else experiencing the same issue?
8The reverse camera is seriously lagging, and the dashcam function isn't working. Does anyone else in the car enthusiast group have the same issue?
9The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
10Is there anyone else experiencing issues with the 2019 facelift 330 Luxury Edition where the keyless locking is unresponsive or not working after turning off the engine?
