محمد عاطف
2023-11-10 03:25
Why do you have to press the rear window button once before starting the 2013 GS5?
Why does my car window go down but not come back up, and I have to press the unlock button repeatedly to open it? [Facepalm]
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
Why did all the windows and sunroof open automatically? I've experienced this once.
Why do I have to manually enable the network every time I start the 2019 GS5?
How do you set the lock on the 2013 Trumpchi GS5?
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
Does the 2013 Roewe have automatic window closing when locking the car, or can the windows only be closed by holding the lock button?
The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
GAC GAC GS5
GAC GS5TBDGasoline
