When starting the 2014 GS5 2.0 automatic, the car shakes for about 10 seconds. It also shakes slightly when shifting from neutral to drive. Does anyone know the reason? Thanks 🙏🏻
When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
Help! When driving on slightly rough roads, the gear shift shakes a lot. Is there any way to fix it? I'm willing to offer a reward for anyone who can solve this problem!
When the car is idling, it feels like it's shaking, but when I shift to neutral, it doesn't. Does anyone know what might be the reason?
4I have a 2009 Touran 2.0 manual, and I'm having trouble shifting into first and reverse. Is anyone else experiencing this? Also, when I release the clutch in first gear, the engine shakes like it's about to stall. It also shakes a bit during rapid acceleration. Is this normal?
5Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
6My car has been driven 90,000 kilometers since 2013. It's shaking when idling, and there's a jolt when shifting from Neutral to Drive. Has anyone else experienced this issue? Could it be time to replace the engine mounts?
7Gv80 shifts to neutral at a red light, makes a thump sound when starting.
8When shifting from D to neutral, there is a clicking sound. What could be the problem?
9Is it normal for a used 2021 Forester to noticeably shake from side to side when revving in neutral?
10When starting the 2014 GS5 2.0 automatic, the car shakes for about 10 seconds. It also shakes slightly when shifting from neutral to drive. Does anyone know the reason? Thanks 🙏🏻
