What could be the reason for not being able to shift gears when the car is cold?
What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
4Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
5Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
6The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
7What could be the reasons for not being able to shift gears?
8What could be the reasons for not being able to shift gears?
9What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
10What could cause a car to shake when starting cold?
