علي طل
May 21
The recommended tire pressure for the old model GS5 is typically around 2.1 bar, so having all four tires at 2.1 should be fine. However, it's always best to check the vehicle's manual or the placard on the driver's side door jamb for the exact specifications.
The Dragon Edition of the 570GT refers to a special edition of the McLaren 570GT. However, specific details like the year and exact model version would require additional context or information, as special editions can vary by region and release.
If you're considering changing the tires for your Kia Pegas, it's best to choose a brand that is known for quality and performance. Popular tire brands like Michelin, Bridgestone, and Goodyear are often recommended for their reliability and durability. Make sure to select tires that match the specifications and size needed for your vehicle to ensure optimal performance and safety.
4Looking for four original wheels and tires 235/45 R17, the newer the better. Just the four wheels alone are also fine.
5The timing belt in a Kia Sportage engine typically needs to be replaced every 60,000 to 100,000 kilometers. However, it's always best to check the owner's manual or consult with a professional mechanic for the most accurate maintenance schedule for your specific vehicle model.
6The 2015 Volkswagen Touran with an automatic transmission uses a timing belt. It is typically recommended to replace the timing belt every 60,000 to 100,000 kilometers, depending on the manufacturer’s specifications and driving conditions. Always refer to the vehicle's manual or consult with a professional mechanic for the most accurate information.
7The tire pressure is fine, but the tire pressure light came on this time it snowed. What's going on?
8Can someone tell me what the usual tire pressure for a Mazda 2 hatchback should be? Some say 2.5, others say 2.3. What's the best pressure? Thanks!
9The recommended tire pressure for the old model GS5 is typically around 2.1 bar, so having all four tires at 2.1 should be fine. However, it's always best to check the vehicle's manual or the placard on the driver's side door jamb for the exact specifications.
10How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
