Is it a problem if my GAC GS5 occasionally shows error codes? How can I fix it?
Do you guys have issues with the passenger airbag showing error codes? Mine was fine in the morning, but in the afternoon, it started showing an error code. Have you experienced this?
Is there anyone with a 2020 GA8 experiencing occasional engine shaking and exhaust fault codes? How did you solve the problem?
4I want to ask the car enthusiasts here, does the 2021 GAC GS5 often show the "check emission system" warning? Mine does this frequently.
5Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
6Is it a problem if my GAC GS5 occasionally shows error codes? How can I fix it?
7After changing the brake fluid in my GAC GS5, the brakes failed. I thought it might be an issue with the master cylinder, so I replaced it, but the problem still wasn't solved. Can any experts offer some help?
8Hey guys, my car is showing error code P048013, which is about fan 1 control circuit, general electrical fault, open circuit. Has anyone encountered this error code before? Thanks.
9Hello fellow car enthusiasts, when I open the GAC Smart App, it shows a certificate error and asks me to upgrade the app. Can anyone tell me how to upgrade it and where to do so? Thanks 🙏🙏🙏
10I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
